Yet another porsche caliper question
  • porkkis
    • 1994
    Simply:
    Will std RS2 calipers (304mm) + RS2 caliper carriers + 314x30mm C4-urS/A8 disk bolt on to S2?
    Yes/No, nothing else needed
    If yes, I'll purchase the RS2 carriers, if no I have them custom made.
  • Mikes2
    • 1704
    Yes and no. The discs will need machined from 314mm down to 304mm or you'll need to space the caliper to accomodate the disc and use the longer bolts.
    Apart from that it's bolt on. The Porsche calipers are probably better than the RS2 ones as they take the thicker Porsche pads.
    Mike
    http://www.s2-audi.co.uk
    • porkkis
      • 1994
      Thanks.
      I already have purhcased a pair of rs2 std calipers.
      • Mikes2
        • 1704
        Don't forget that you'll need hoses as well. The S2 ones are too short.
        Mike
