Originally posted by WabTheKing
Rear Brake Setup
this one, £36+vat just got to space it so it will fit a 25mm disc and make a bracket to bolt it to thoes two bolts where the suspension leg bolts onAttached Files
rear boxster monoblocks on a 25x260 disc,
should look somethin like thisAttached Files
Think you have to remember Wab's car was an 7A car, looking at the pics thats a 4 stud PCD.Originally posted by Greg_SIs there a thread with the full write up on this? Which discs are you using? did you make up custom carriers for the caliper?
Unless you've changed and are using 5x112 hubs Wab?Last edited by Jamo; 23 May 2005, 14:05.Comment
carriers not made up yet, discs i think are off the front of a 2.0lt coupe (have to check)
will measure the offset of this disc so you can find some 5stud ones, i dont wanna change my wheels so thats the only reason im staying with 4stud, from a disc choice it would have been alot easyier with 5 stud!
will do a proper drawing for the carriers so who ever wants some can make em or i can make em for you
