Hi after reading through the forum on brake upgrades i have been keeping a close eye on ebay for some porsche 996 calipers and found these. Just need to know if these would fit my standard s2 if i got the a8 discs.http://cgi.ebay.co.uk/ws/eBayISAPI.d...sPageName=WDVW
will these fit?
they are 6 pots afaik so you would have to get custom brackets and I'm not sure the A8 discs would be wide enough.
Can't answer 100% so you'll get more response's, sorryMark
Race Clio RS197
S2 Coupe ABY (Green) - RIP
S2 Coupe ABY (Blue) - SoldComment
maybe chris u could let a rival know if they would fit? I take it by u bidding on them u know they would fit. What discs would u use with them3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
I'm sure you can get some brackets made up to fit, or if i was to win them then i could compare them to see how they look up against the 996 mounts from Martin. Not sure on disc size, i've asked him to e-mail me the original disc size and thickness to give me a idea of what would be needed.
HTH,
ChrisCheers,
Chris
Silver S2 Avant : Sold
I was bidding on a simular set on ebay about a year ago and IIRC the guy wanted £550 to end the auction early. They were yellow 6 Pots with 350mm discs. I'm just trying to find if Audi do a disc thick enough. Might need 32mm wide. The guy hasn't got back to me on disc size yet
Cheers,
ChrisCheers,
Chris
There's 2 sizes of A8 discs which might be suitable, 323mm by 30mm, which is what i have and 345mm by 30mm. Alternatively there is the RS6 disc which is 365mm by 34mm. What size wheels have you got?
Cheers,
ChrisCheers,
Chris
No I didn't mean with the 6 pots - just with 996 4 pots
Waste of time trying to get these under 16" wheels.
What size does Karl in oz run with his GT3 calipers?Kingdoms are run by Kings, Dictatorships are run by Dictators.
England must be a Country. :mischeif:Comment
, i was on about steves question
