Where do I get spindel to coupe quattro??
  • eXtreemeRS
    • Feb 2005
    • 56
    Hello!!
    I got a Audi 90 quattro 89 mod.
    I have installed a 2,2 20v turbo 3B engine..
    The only thng I havent changed yet is the brakes...hehehehe...
    I got new s2 calipters and discs but i need the spindel because I still got spindels
    from my 90 quattro on it..
    So I need spindel from a coupe quattro..
    anyone got it??or know where to get it... I'm a safe buyer!!!
  • porkkis
    • 1994
    Styrspindel?
    Hub carrier that is. Use a hub carrier + hub from A90 2.3 20V or Coupe 2.3 20V = 7A engine, FWD or quattro, does not matter. It has the same hub carrier as S2 but 4 bolt hub. Use S2 parts if you want 5 bolt hubs.
    Note! These hubs use a bigger bearing and you need a suitable drive shaft outer CV joint too! And the joints are not interchangeable so you need the whole shafts from 20V quattro. 20V FWD has 108mm inner flanges so if you use the FWD shafts you have to change your old 100mm flanges to S2 flanges! Coupe and sedan have different length driveshafts!
    • caterpillar
      • 2480
      look at www.be-4-you.com the parts are on the forum there
