Frout Brakes Rs2
  • jade
    • Jan 2005
    • 1811
    Frout Brakes Rs2
    Just done frout brakes pads, new lines , disks , changed fluid
    brake are pulling up well on hard brakeing , but around town light brakeing suddenly
    just as your about to stop the pedal go hard for a second then back to normal .
    like maybe the abs pumb kicking in or something not sure any ideas
    Thanks Jade
    RS 2 580HP
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Thanks Jade
    Seems that either bomb or PAS pump is giving up. It can be both also. Usually (!) symbol under heavy braking means, that PAS pump is not giving enough pressure, and pressure accumulator, known as bomb is not managing to compensate that.
    Sau
    • dan_b
      • Sep 2003
      • 3670
      Are you getting a brake squeal at the same time as this symptom comes in?
      I'd suspect one of your ABS sensors is on the way out.
      • jade
        • Jan 2005
        • 1811
        I been wondering this i did move one of the sensers back and forward when changeing brake lines
        RS 2 580HP
        • dan_b
          • Sep 2003
          • 3670
          Sounds like it could just be loose, or a bad connection maybe, or perhaps it's broken? Worth checking out I'd say.
          • jade
            • Jan 2005
            • 1811
            Think i might just change both , do they just unplug or what ???
            Regards Jade
            RS 2 580HP
