Brake line ans bleeding question....
  • panzerwagen
    • 900
    Let's say you break open the right side break line and replace it. Is it necessary to bleed the entire system or is it ok too just bleed out that replacement line? Since each brake line is seperate from the other, no air or debris should contaminate the other lines?
  • Berserker
    • May 2004
    • 15
    As long as you don't empty the MC, you should probably be OK.
    If you don't get a firm pedal, it's only another 30 minutes-1 hour to bleed the entire system.
    Good luck!
