Sticking speedo
  • dan_b
    • Sep 2003
    • 3670
    Sticking speedo
    I first got this at the Baschurch Garage Meet this year - my speedo started sticking after about 2.5 hours of driving, all of which was with the lights on. It went away and I assumed it was "just one of those things", but it surfaced again at the last 2 weekends when I spent an awful long time stuck in lots of hot traffic.
    My speedo now seems to get stuck after about 1hour's worth of driving. Giving the dash a firm tap will free it up again, and if you stop and let the car cool down for a while it'll work fine again. There are no visable signs of peeling or anything on the dial paint. Does anybody else have this problem? Any solutions? I'm wondering if it's heat related still though? I always have the dash back-lights up on full intensity, but it's been very hot and humid in the UK and I've been sitting in a LOT of traffic (and my air-con doesn't work) so the car's been getting HOT inside...
  • Martynf
    • 1885
    Dan, its normally always some paint lifting off the face of the clocks or something inside causing the shaft to stick, hence only when hot things expand. Personally, I'd take the speedo out and gently find where the clearance issu is and fix it. Time to rip the dash out....
    Martyn
    www.vagparts.com
    • s2driveruk
      • 12696
      Yep, Martyns right, it'll be the paint lifting probably just underneath the mileometer - i was sure mine wasn't lifting and something else was causing it but then on removing the instrument cluster and looking carefully I spotted where it started to curl upwards and interfering with the needle above about 50mph. Used a craft knife to cut it away and voila - no more probs.
      Cheers,
      David
      1992 3b S2 Coupe
      • pastures16
        • 2058
        martyn is totally right try this link for stripping the cluster http://www.mnsi.net/~natwhite/Audi/I...entcluster.htm
        94 s2 avant
        aoc member 1116
        • dan_b
          • Sep 2003
          • 3670
          The whole concept of taking out the instrument cluster fills me with fear to be honest! Yikes... Who else has done this?
          • Ian Simmonds
            • Jun 2005
            • 2858
            I've had the instruments out several times to replace bulbs and even replace the 'grain of wheat' bulb for the external temperature guage. If you've got the maintenance manual for the Series 3 Coupe, follow the instructions and you won't go far wrong. It really isn't that bad a job, but start earlier in the day rather than later. (I did a 'quick bulb fix' on mine one winters afternoon and ran out of light, which isn't helpful).
            Remember to park with the front wheels straight so the steering wheel goes back on 'true' and generally make sure all the connections are pressed home firmly when you put it all back together.
            Take your time, you'll be fine - and don't 'force' anything.
            Good luck
            Ian
            93 MTMS2 Avant
            • dan_b
              • Sep 2003
              • 3670
              I guess it's the fear of the unknown isn't it!
              • pastures16
                • 2058
                i did a white dial conversion takes time to get rid of the hot spots http://www.audifans.net/modules.php?...view_photo.php
                94 s2 avant
                aoc member 1116
                • s2driveruk
                  • 12696
                  its a doddle job Dan - even i managed to do it with my mit-like fingers If you fancy a hand then happy to help....
                  1992 3b S2 Coupe
                  • Skull
                    • 3506
                    • Country: Slovenia
                    One advice. Pay atention to the lever of the fuel gauge. Dont turn it or else...
                    Audi Quattro WR
                    • rotoryboy
                      • May 2004
                      • 3281
                      Yes, Ask Jas's bro about that
                      Mark
                      Race Clio RS197
                      S2 Coupe ABY (Green) - RIP
                      S2 Coupe ABY (Blue) - Sold
                      • s2driveruk
                        • 12696
                        aint that the truth lol
                        1992 3b S2 Coupe
                        • dan_b
                          • Sep 2003
                          • 3670
                          Drat, it's doing it again only more regularly now. On a 2-hour drive at the weekend it was firmly stuck at 60mph pretty much most of the way. Even when turning the ignition off it still stayed where it was. I really can't see any signs of paint peel though, but I guess it's the first thing to try. I don't have a copy of a manual, are there any photo BTDT guides for removing, and replacing back again, the dash console?
                          • Jas11n
                            • 5067
                            Taken from Paul's S2 central site, and MikeS2's site
                            Removing cluster, same again but with pics here.
                            and
                            Dismantling the cluster
                            It's not as bad as it looks really
                            The clocks will come out without removing steering wheel (I've got an airbag wheel so it has to) but it's not hard to remove the wheel, 24mm socket needed to remove it.
                            2001 Avus Silver B5 RS4.
                            1995 S2 Coupe - sold (sniff)
                            • dan_b
                              • Sep 2003
                              • 3670
