Autocheck/boardcomputer
The yellow connector with about 5 wires is for outside temperature display
The white connector is for Autocheck feature
The small black connector is for Onboard Computer
The long blue connector is for normal dash (like your original)
The long yellow connector is for normal dash (like your original)
The 'new' dash won't work in you car without the rest of the wiring loom from the donor car - the normal features your car has will work, but not the computer, temp. display or the autocheck. If you just plug your original yellow and blue connectors, the autocheck display will continiously display the "oil" symbol and bleep each time you start the car.
It'll drive you mad, the correct wiring loom is "plug and play".Never show a fool a half built house.
Never underestimate the power of stupid people in large groups.
Life is like a **** sandwich
The more bread you have, the less **** you eat
