Cruise Control Installed..
    Schematics here BTW - http://www.s2central.net/S2_Schematics/B/B68.PDF
    WHat blue plug are you on about ?
    SOmething is amiss though - I cannot line up schematics to my CC loom here and make sense of it back to this http://www.s2central.net/S2_Schemati...tic_Primer.pdf
    I remember finding a funny a few weeks back on cruise wiring but I cannot find details of it - drat.
    Paul
    • mcandmar
      • Apr 2004
      • 5118
      You know where the green plug goes in the auxiliary panel OK - as per T10c and Page 12 of this - http://www.s2central.net/S2_Schemati...tic_Primer.pdf
      The blue plug that is supposed to connect to the loom in the car. I found the brake light and VSS wires, not having any luck with the power feed. Where is the fused side of S12 in the birds nest?
      Not with you on the green plug
      Cheers,
      Mark.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
        Ahhhhhhh - that photo is priceless. Now I get it....
        Of course my loom & CC are from older USA model so that explains some oddballs....
        FUsed side of S12 is used already - seen at T26a/16 on track 2 on http://www.s2central.net/S2_Schematics/B/B68.PDF
        I need to look at US cruise diagram to retain my sanity.
          OK - sanity restored....... Remembered the trick now - B68 is wrong schematic... Should be B08 as the cruise wiring is different on cars equipped with headlight beam control - go figure. I'll upload the right drawing later. Makes more sense now... T5f is the blue plug on the aux panel - which lines up with my primer. Phew.
          • mcandmar
            • Apr 2004
            • 5118
            So is mine, came from a US spec CQ20v. Its identical to the kit i installed in the CQ.
            The fuse S12, black/blue wire. Can you tell me where to splice it in as i cant figure out the bottom of the fusebox. i.e. which connector/wire? I think you mentioned somewhere its shared with the reversing lights.
            Thanks,
            Mark.
            • mcandmar
              • Apr 2004
              • 5118
              Sure, that makes sense
                #22
                Here is D08 for now... (not B08)... The wiring colours almost line up perfectly with US based schematic but not quite. I'll upload that in a jiffy.
                  #23
                  That black/blue wire is on south side of Fuse 12 - see track 2 where you can splice in and also track 26 at the headlight adjuster switch where you can access the same signal.
                  • mcandmar
                    • Apr 2004
                    • 5118
                    So the back of instrument cluster or headlight adjuster. I will go and stuck my head under again and see if i can find it...
                    Thanks Paul,
                    Mark.
                      #25
                      To complicate matters further - the Cruise loom I have is from an automatic US model - well according to Bentley anyway... My loom has a sticker 893 971 425 C and date of 16.07.90
                        #26
                        This loom conveniently has a 3-pin plug that connectorises black/blue (S12), red/black (S3 and brake switch) and blue/white (VSS) - but I cannot yet track that to ABY... I like the challenge though
                          #27
                          OK then...
                          red/black from brake switch shown here http://www.s2central.net/S2_Schematics/D/D44-10.pdf at Track 102 on T10b/5
                            #28
                            black/blue is T26a/16 on track 78 of http://www.s2central.net/S2_Schematics/B/B73-07.pdf
                            blue/white (VSS) is T26a/18 on Track 82 of same sheet
                            • mcandmar
                              • Apr 2004
                              • 5118
                              Exactly, my CQ20v had a blue plug for it to connect into, the ABY Avant does not. Hence the above fun and games of splicing wires.
                              Found the black/blue at the back of the headlight adjuster and spliced in. Its a very thin wire so i'll poke around tomorrow in the day light and see what its like at the cluster. I would have expected heavier gauge wiring to supply the pump.
                              Thanks again
                              Mark.
                                #30
                                Yeah well that makes sense at least - the US 7A loom is plug compatible with UK 7A... The cruise loom is different on 3B and ABY S2 applications. I'll have a look at other cruise schematics to see if this is cleaned up anywhere - would be neat to connectorise an adapter for that blue 3-pin plug.
