well all thats displaying is _ _ _ is it the sensor or the lcd display thats nailed also theres no back light
outside temperature display
Tags: None
If you can see no digits (however faint) it is not the backlighting alone BTDT. Could be sensor under front bumper (worth locating and spraying with WD40) or unit that fits behind dash.
However I replaced all and still get same due to the 'wiring' behind the display dying with age. My specialist could take it all out and repair but I have not got round to it.Alastair
RS2 -
Si (Pastures) I've got a spare unit if you need it, which has already had the backlight sorted, but sounds as Alastair says in that it's not getting a signal. I'll bring it and a spare led to the NEC with me.
On another note.
Si (HPmuirt), I forgot about this, Mark mentioned that yours was flashing allsorts up like a mini disco. Is that right? If so it's just the display (LCD), BTDT with one I fixed for someone.
I've got a spare display (yep I've got a couple
) if you need it.
Jas
1995 S2 Coupe - sold (sniff)Comment
Hey mate,Originally posted by FourringsSi, I forgot about this, Mark mentioned that yours was flashing allsorts up like a mini disco. Is that right? If so it's just the display, BTDT with one I fixed for someone.
Or does it just read _ _ _ _ "all" the time, if so it could be as Alastair says.
I've got a spare display if you need it, and I can also sort the backlight too. I'll bring them with me to the NEC.
Jas
Yup, some of the segments are out from each group so none of the numbers are displayed properly....some of them go on and off and others stay off....damn annoying
The back light is fine.
When it first happened I disconnected the sensor and it showed - - - - so I assume the sensor is not at fault but the display itself.
I'll def take you up on your spare...cheers matey
Cheers n
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available
(except a towball)Comment
cheers ja look forward to seeing you and your bro again is he driving thenOriginally posted by FourringsSi (Pastures) I've got a spare unit if you need it, which has already had the backlight sorted, but sounds as Alastair says in that it's not getting a signal. I'll bring it and a spare led to the NEC with me.
On another note.
) if you need it.
Jas
94 s2 avant
aoc member 1116
