Headlight wiring differences
  • porkkis
    • 1994
    Are the h4+h1 and ellipsoid h1+h1 wirings similar or does the ellipsoid models keep low beams on when using high beams?
  • Martynf
    • 1885
    They are different Porkkis. Mik was going to do this mod. I think Paul said he might have the diagram on S2central some time in the future. When you go to high beam on the Ellipsods, low beam stays on.
    Martyn
    Martyn
    www.vagparts.com
    • porkkis
      • 1994
      Ok, thanks. No need for diagrams, easy job.
      • porkkis
        • 1994
        Actually I don't recommend modding the wirings unless there is trouble with snow. I mean that the only reason why low beams stay on is that the heat mets snow.
        Leaving lows on just harms focusing to the distance as there is a bright spot near the car.
        • Martynf
          • 1885
          thankfully snow is a problem we don't often have here!
          Martyn
          www.vagparts.com
          • porkkis
            • 1994
            Thankfully snow+quattro=fun
