Just bought an ur S4 and i need some eletric shematics and need to know the fuse loca
  • zlobo
    • 967
    I need some eletric schematics, were can i find them?
    Is there a fuse for the start motor cause now i don't get the car to start, there is no clic or nothing.
    the eletrical fan i runing al the time what may cause that?
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • BRY
    • 3755
    Is this any good?
    It's in German
    • ~Delta
      • Apr 2005
      • 797
      No fuse for starter motor . Check:
      1) Starter inhibitor switch (if it's auto)
      2) Ignition switch
      3) Starter motor
      4) Bridge strip in fusebox (if it's manual)
      5) Possibility of an old immobiliser (aftermarket) malfunctioning
      Never show a fool a half built house.
      Never underestimate the power of stupid people in large groups.
      Life is like a **** sandwich
      The more bread you have, the less **** you eat
      • zlobo
        • 967
        its an manual,
        i will check if there is power to start motor relay.
        There is no aftermarket imobelizer there is only audi orig alarm.
        kostic.nu
        • iain1067
          • 984
          The fan running all the time would most likely be the fan relay known problem on those
          • Mikes2
            • 1704
            I had this on a Audi 90. 2 problems. The battery was low at ~8V. As soon as this was connected the fan started.
            Clifford alarm was preventing any ignition - this was removed and the car started no problem.
            Check the battery and go from there as it sounds like it's low
            Mike
            http://www.s2-audi.co.uk
