AC/Heater problems
  • Bowlerwell
    • 1052
    AC/Heater problems
    My car has a history of a rattly AC clutch.
    A couple of days ago, I noticed that It was taking AGES for warm air to come through. It used to get warm even before my water temperature was at 50*C. NOw it's still cold at 60, 70, 80, 90*C.
    The light behing my AC switch no longer illuminates, I fear it is not engaging. Once i'm moving and up to temperature (90*C), I get warm air, but it takes a LONG time.
    Please help me.
    Any ideas folks?
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • dan_b
    • Sep 2003
    • 3670
    The light behind the AC switch stops illuminating in cold weather - this is normal: when ambient air temperature falls below the level at which the AC can cool the air any further for the car - ie therefore in very cold weather, the AC actually disables itself.
    I suspect the reason it's taking you longer to notice warm air is also because the outside air is colder and the car is taking longer to dump excess heat in to the heating system. Again I think this is probably normal. I would go and check your water levels though and make sure you've got enough winter anti-freeze in there?
    • Bowlerwell
      • 1052
      Thanks Dan.
      John Bowlerwell
      Electronic Engineer
      Present:
      Previous:
      • GlynRS2
        • Dec 2003
        • 307
        Thanks for that top tip Dan.
        I noticed this yesterday when I went to use the AC to aid demisting the screen. Thought that might be the case, but also had a fear of something expensive had gone wrong. Feel much relieved now.
        Glyn
        Ex-Polar Silver RS2
        Sprint Blue RS4 - new toy :mischeif:
        • Sidspud
          • 1223
          • Home: Scotland Current: United Nations
          Anything below 5°C and air-con will not work
          ex '93 Avant owner
          • dan_b
            • Sep 2003
            • 3670
            There you go, got an exact temperature now too!
