G28 engine speed
  • marty
    • Nov 2003
    • 55
    G28 engine speed
    hi could anyone help have just fitted new hall sensor and car now starts but vag com now says 1 fault engine speed sensor (G28) 03-00 no signal . As i say can now runs. Can anyone tell me what are the impications of no signal from speed sensor.
    Thanks in advance
  • topsparky
    • Oct 2005
    • 2014
    Thanks in advance
    i think it's because the car is n't moving
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • marty
      • Nov 2003
      • 55
      never thought of that worth a try cheers
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Sounds normal to me.
        SS
        • marty
          • Nov 2003
          • 55
          What you neen it normal to have fault??
          • s2avant
            • 2426
            G28 only recieves a signal when the engine is running hence the fault code when the engine is off.
            Clear the fault codes and try it with the engine running. If the G28 code is still there then there is a problem but if not your all clear
            Ben
            • marty
              • Nov 2003
              • 55
              that makes sense will try tomorow after ive given it a run cheers
