fuse, diagnostic circuit
  • ian_jemo
    • Aug 2004
    • 284
    Does anyone know where it is??
    I'm trying to pull blink codes but I sure I have blown the fuse.
    Ian
    1991 S2 3b, Samco Hoses, RS2 IC, 18'' RS6 Wheels, Forge Dump Valve, Scorpion Exhaust System, Decatted, MRC Remap
  • Faheemo
    • Feb 2005
    • 544
    • Country: South Africa
    timing fuses ?
    S2 Coupe fully built.
    10.9 1/4mile 0-100 in 3.5secs
    Precision 6262 turbo
    The Green Monster
    • ian_jemo
      • Aug 2004
      • 284
      Don't know if it os those fuses or not. I thought the fuse would have been inside the car near where you get the blink codes from?
      • ian_jemo
        • Aug 2004
        • 284
        I had a look in the fuse box but couldn't find which one I need to change.
        The car is a 3b model so I think the fuse layout above is different.
        Does anyone know where it is I really need to pull off any fault codes?
        • Nuvo
          • Nov 2003
          • 3826
          Ian, according to this wiring schematic it is a 10A fuse S21.
          • ian_jemo
            • Aug 2004
            • 284
            Thank you for that, I will have a look.
            Where do you think it is, In the fuse box or near the diagnostic connectors??
            • Nuvo
              • Nov 2003
              • 3826
              Your question concerns me a little, are you sure you know what you are doing?
              I would expect it to be in the fuse box, the sticker on the top should identify where fuse numbe 21 is.
              • ian_jemo
                • Aug 2004
                • 284
                Ok I will have a look.
                No its just I have seen that there are some fuses above all the foot pedals as well. Just thought it might have been somewhere there
                Ian
