Oil warning light....
  • jubjub
    • Nov 2003
    • 1239
    Don't actually know why i did not ask ages ago.....Get in the car, turn the ignition on (with the engine off) wait a few seconds then Beep Beep Beep and a flashing picture of an oil can. What does this mean,I was told ages ago from Whitehouse Audi (Dartford) that it was normal. Apparently it comes on because it is an oil pressure warning, and because the engine is not running it obviously has no pressure. Is this correct? Does anyone else's do this? Can it be stopped,cause it is annoying?
  • Vagsport
    • 533
    It IS normal, Dean. Cheapest fix to this 'annoying' problem is to get into the car AND start the car straight away, don't need to wait a few seconds, do you?
    Siena
    • jubjub
      • Nov 2003
      • 1239
      • Martynf
        • 1885
        I wouldn't of believeed this unless Siena said so! weird isn't it? that's another thing I've learnt today. Well I'll be!!
        I remember that the oil pressure switches if they spring leaks can cause this fault, and also the buzzers used to be really faulty on Mk2 Golfs, but never heard this one before!
        Martyn
        www.vagparts.com
        • jubjub
          • Nov 2003
          • 1239
          Yeah i know, had me worried for ages.The only other car i really looked at was another (silver) Rs2 in Bexleyheath( the guy has sold it) I checked to see if his did the same but it did not and i then thought that mine was ******ed....should have given the car a bit more credit
