hi, i'm about to undertake the task of installing a 20v turbo 3b motor into my urquttro. a garage here on the isle of man where i live will be doing the install. i'm just looking at ways i can cut down the install time on the electrics side. i have the 3b engine,wiring loom and ecu among other bits. ideally i would like to lable up the loom so it is easy to see what connections go where. is there any info/pictures about that will help me do this. i have printed off alot of info relating to the 3b motor, electrics, ecu and also alot of posts about previous similar converiosns thanks to you guys. hopefully this will cut down the labour time on the install. any other info that your think might help would be great too.
thanks
thanks
