***Important first****
This thread has nothing to do with any problem on the HID kit.
Two months ago I installed Martyn HID kit and everything worked perfect one week later when I got inside the car on the morning and turned lights on I got a fault bulb warning on the Instrument cluster display
. After checking everything no bulb was found with a problem. Bulb problem went away within seconds, but everytime I switch the lights on the bulb warning stays on for 10-15 seconds and then disappears.
After talking to Martyn he suggested it could be the earth point I took was not good so I try alternative positions but nothing worked
Some days later while trying to solve the problem I disconected the front right headlamp unit and when I turned the lights on no fault bulb was seen
So I got inmediately a replacement ballast from Martyn to see if that was the problem but it did not work.
In desperation I disconnected the HID kit in the front light headlamp and fitted the halogen bulb and still got the fault warning
so I though it could be a bad connection within the headlamp.
Yesterday morning I got to pieces the headlamp and checked/clean every connection and still have the fault bulb warning :wacked:
Showing everything to a friend he told me to try and disconnect the left headlamp and leave the right one connected to see what happened and I got no fault warning
So for summary, all bubs work perfect but I get a fault bulb warning everytime I turn lights on also I have seen it a couple of times during heavy trafic while they are on. If I disconnect one (either) of the headlamps through the big round connector with four connections I get no warning
I need some help because is driving me crazy
Rafael
. After checking everything no bulb was found with a problem. Bulb problem went away within seconds, but everytime I switch the lights on the bulb warning stays on for 10-15 seconds and then disappears.After talking to Martyn he suggested it could be the earth point I took was not good so I try alternative positions but nothing worked
so I though it could be a bad connection within the headlamp.Yesterday morning I got to pieces the headlamp and checked/clean every connection and still have the fault bulb warning :wacked:
Rafael
:wacked:
