Revcounter not working & ambient temp display
  • Jas11n
    • 5067
    A good little tip for the difflock bulbs.
    If anyone can't find a suitable bulb, or Like Si (HPSauce) found that his were a tad too bright,
    Then use some of the tiny wedge fitting bulbs that are used in some of the switches, ashtray light, cig lighter etc.
    Just bend the legs down, poke em through the PCB and solder away.
    Jas..
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
      • 12431
      Cheers Jas, Ive found some that should be a straight fit from maplins, order code BT43W 69p each and a 16000 rated life
