Passenger window problem
  • Graham
    • 1622
    Hi
    I now live in Queensland and am desperatly in the process of fixing my Air-con which has a leak somewhere, so in the mean time i drive with the windows down, and sunroof open (Its hot!!).
    Recently i have had a problem where the passenger window refuses to work of either button, when i press the driver button, the light in the passenger switch goes out then back on when i release the button, i play with the buttons for a few tries and eventually it works again.
    Any idea's?, i thought possibly the main relay, but surely if that was faulty nothing would work, yet i can still operate the drivers window and the sunroof.
    All the best
    Graham
  • Crawford_S2
    • 1555
    Sounds like motor is on its way out, had this on a golf. It turned out to be water ingress in motor had wrecked it. It was an intermitent failure for ages but if the light goes out on the switch when you use the other one for the same window that sounds very much like there is juice getting to the motor but its not well!
    Ragusa Coupe gone!
    • Graham
      • 1622
      ********, does anybody have a spare what they want to sell??
      Cheers for the info, i thought there wouldnt be a relay fault as the relay powers the sunroof and drivers side aswell.
      Graham
      • Graham
        • 1622
        Also on the aircon problem, alot of people have pointed out the pipe which goes into the wheel arch, how much is this pipe??
        Graham
        • ~Delta
          • Apr 2005
          • 797
          I have a good passenger side electric window assembly, Graham.
          Never show a fool a half built house.
          Never underestimate the power of stupid people in large groups.
          Life is like a **** sandwich
          The more bread you have, the less **** you eat
          • Graham
            • 1622
            PM Sent.....
            • Graham
              • 1622
              Right, following on from this, today it would go down but not up, surely if the motor was heading south it wouldnt do anything--Would it???--Help, were headding into rainy season and i dont want this to go **** up when it pours down.
              Graham
