Hard wiring a cigarette lighter app.
  • S2 PTH
    • Dec 2005
    • 421
    • Home: Wales Current: United Kingdom
    Looking for a solution to a wire dangling over my dash coming from my road angel to the 12v cigarette lighter! I have bought a hard wiring kit from ebay and now am wondering if there are any spare fuses or whatever to do this...? Also, does anyone know of a good route to take this wire and to have it popping out around about where the windscreen vents are?
    Cheers in advance,
    Phil
    ...ever since I floored you I knew that I loved you!
  • topsparky
    • Oct 2005
    • 2014
    Cheers in advance,
    Phil
    vagparts do an auxiliary socket that pops uphttps://sslrelay.com/s74326199.onean...dex.shopscript
    check the electrical section
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    8. fmic fitted
    • S2 PTH
      • Dec 2005
      • 421
      Yeah, but where am I going to put that, on the dash? LOL
      The wire I have has a bear wire at one end, so having a spare 12v socket isnt much use. Apparently I've heard that you can just link this into the fuse box wherever or whatever that is!
      • topsparky
        • Oct 2005
        • 2014
        as long as you fuse it down to protect the equipment you can connect it to any 12v supply
        sorry about the confusion ithought you wanted it so it was removeable
        1. SHORT SHIFT KIT
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        8. fmic fitted
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Obviously use a cicuit that can be used for whatever current you intend to draw.
          The cigarette lighter would be a good bet.
          SS
          • terrybullwon
            • Mar 2006
            • 8782
            I tried this on the cigarette lighter so i didnt have so many chargers etc, i made a fused curcit and blow my nokia up
            Sorry for the useless info i hope you have more luck!
            Chef
            • S2 PTH
              • Dec 2005
              • 421
              Oh, i guess no1 knows how to do it then! I was under the assumption that I could just wire it up to a spare fuse in some electrical box?!
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                What did you do? Wire it straight to 12V with no transformer?
                SS
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Yeah i used a step down from lucas but i fried it at the same time My knowlege of electrics is really bad
                  Chef
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    wtf? How does your cigarette lighter socket get its power?
                    SS
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      You're probably better off pulling apart a cigarette lighter adaptor made for charging the phone, then connecting that to a 12V circuit. I don't spend much time with the phone plugged in, so I haven't really looked into it.
                      SS
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        well i tried it on the phone before i pluged it into the snooper as i didnt want to blow that up. At least the phone was covered
                        Chef
                        • john881000
                          • May 2004
                          • 598
                          Power Point
                          HI
                          IF YOU NOT LEAVING UNIT PLUGGED IN ALL DAY/NITE BUT DISCONNECTING IT
                          YOU CAN CONNECT TO FUSE BOX TO ONE OF MANY SPARE BIG TURMAILS ON FUSE BOX
                          I CONNECTED MY BOOT SPARE JACKING POINT ( for electric boot cooler box..and electric tyre pump )
                          AND A POWER SUPPLY TO MY AMP AND PHAT NOISE
                          ONE FUES BOX(underneath )IS A FEW BIG SPADE TERMINALS 8 OF THEM.....ON LETTER L SOME WILL BE USED FOR ELECTRIC WINDOWS ETC
                          I USED A VW/AUDI FUSE HOLDER TO FUSE BOTH SYSTEMS (PARTNO ESCAPES ME NOW BUT WILL FIND AND POST LATER)
                          SLIDE IT ON SPARE LOCATION UNDER DASH PANEL ON DRIVERS SIDE
                          IF YOU LOOSEN THE TWO BOLTS ON SIDE OF DASH....WILL GIVE ENOUGH CLEARANCE TO FEED CABLES ONTO DASH PANEL/WINDSHIELD
                          HOPING THIS MADE THINGS CLEARER
                          cheers
                          john
                          • rotoryboy
                            • May 2004
                            • 3281
                            Dude, Capital letters mean you are SHOUTING
                            Mark
                            Race Clio RS197
                            S2 Coupe ABY (Green) - RIP
                            S2 Coupe ABY (Blue) - Sold
                            • john881000
                              • May 2004
                              • 598
                              sorry
