I have barely looked at the car for months now while I've been working my balls off, but I do take it for a spin now and again to keep things moving etc. recently I did so and had the windows down for some air. The passenger's side window only went half way up though. It went down again, and up and down several times but didn't get any further than half way. (At one point a couple of months ago neither window would move at all and I couldn't lower them, but when I went back to the car later they worked.)
So anyway I took the door card off to look for a problem with the runner being jammed or the cables being snagged/worn etc. I didn't see anything obvious, reconnected the switch and the window decided to work again. I don't see anything obvious but there must be an issue of some kind.
So I'm thinking relay maybe? switch problem? or runners need to be lubed. I'm probably not the only person to have experienced this so I thought I should ask for the collective wisdom (cough) of the forum members
cheers
nj
cheers
nj
