Audi S4 won't start
  • hunker7
    • Mar 2014
    • 3487
    Audi S4 won't start
    Hi guys, after a month of good running mine has decided to not start, throwing 00532 code out. Happened to me at the petrol station but managed to get her up and running but now pulled up at home and nothing again?
    Looked up on Ross tech but seems it's a general code and should point towards a specific module?
    had a spare G4/G28 sensor kicking about but no luck with either?
    This gallery has 1 photos.
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    And you've missed those oh so many monthly reminder posts of mine in which number 4 is Potential Reasons why your AAN/ABY/ADU isn't starting?
    You need to go through the list. Suspect the thermal fuses above the UrS4 ECU - change to normal spade fuses.
    • hunker7
      • Mar 2014
      • 3487
      Sorry Dave, don't spend much time at a PC
      I'll go through things as per your post and hopefully can chase it down.
      thanks
      '93 Audi UrS4 Avant
      • hunker7
        • Mar 2014
        • 3487
        Checked everything on that list and all is good. Managed to start her again, turned off, and again couldn't start her. Fuel pump relay engages as I start cranking. Wont start on either lpg or unleaded so I don't think it's fuel related.
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          I think I found the problem, fuel relay. Even though it was engaging something wasn't right, so had a spare put that in and so far 3 out of 3 starts were successful.
          '93 Audi UrS4 Avant
