n75 valve & standalone ecu
  • tango123
    • May 2017
    • 892
    Does a standalone ecu delete the N75 valve?
    If not, is it necessary to run a n75 with a big garrett turbo?
    cheers
  • LHD_Kid
    • May 2006
    • 3697
    Are you mapping it yourself?
    • tango123
      • May 2017
      • 892
      definately not
        You can use the N75 or a different solenoid like the common MAC valve. You definitely need a solenoid if you want electronic boost control. Speak to your MaxxECU dealer, he will hook you up
        • tango123
          • May 2017
          • 892
          might aswell stick with the n75 then
