rev counter not working since ecu swap
  • tango123
    • May 2017
    • 892
    Since fitting a maxxecu the rev counter has stopped working. The settings in the ecu have been changed but it hasn't made any difference. It should just work p&p as far as i know.
    Any ideas??
    cheers
  • sal_s2
    • 1291
    Who did you buy the ecu from?
    • tango123
      • May 2017
      • 892
      from an internet store
      • k.alle
        • Feb 2008
        • 801
        Any ideas??
        cheers
        Does your tacho settings look like this?
        And are you using GPO 8 as output?
        Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
        http://www.garaget.org/?car=52877
        • tango123
          • May 2017
          • 892
          i will check tomorrow
          • tango123
            • May 2017
            • 892
            checked it, an tach adjustment was 0, so i changed it to the same as the pic you sent, but hasnt made any difference.
            • Roach
              • Jul 2008
              • 107
              Might not be the ECU sometimes mine stops working a thump on top of the dash gets it going till I sort out the connections.
              • tango123
                • May 2017
                • 892
                i've tried that also, the day before i swapped ecu, it was working.
                • k.alle
                  • Feb 2008
                  • 801
                  Strange, that should work.
                  Maybe someone good with the electrics can adivse you on how to troubleshoot.
                  • tango123
                    • May 2017
                    • 892
                    strange indeed. thanks for the help though.
