Outside temperature gauge wiring help please.
  • Stick Insect
    • Dec 2003
    • 2338
    Just bought an outside temperature gauge and I could do with some help with what goes at the front end. Behind the dash is easy....
    Can anyone help please?
    David
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...5774&rd=1&rd=1
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    David
    The display simply screws into the back of the instrument cluster, below the bulb cluster, with 2 screws (one at either side) and then the yellow connector plugs into the yellow socket which is on the back of the Speedo. The rest of the wiring is then part of your main instrument loom
    However, on non S cars without temp displays, the yellow connector was not put on the speedo and I therefore suspect that the rest of the wiring may have been absent. I don't know if this is true for S2's without the temp display from new
    If you cannot fit it, lemme know and I'll buy the display
    Cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    • Jas11n
      • 5067
      The actual sensor itself is "4A0 820 535" and is usually sited just behind and below the passenger headlamp. I suppose you could fit it where ever on a retrofit.
      See this post >>> here for the pinouts of the yellow connector.
      Jas..
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
        There is this page as well folks -
        • pastures16
          • 2058
          you got that for a steal mate
          94 s2 avant
          aoc member 1116
          • Stick Insect
            • Dec 2003
            • 2338
            It was a good price, the only downside is that is in Farenheit and not Centigrade.
            Is there a way to convert them?
            David
            • Stick Insect
              • Dec 2003
              • 2338
              I'm sorry I forgot to say thanks for the responses.
              I have the yellow connecter ( I would not have even thought about this project with out it!)
              I need a thermister and the cable, I wonder if there is a chance of getting one freom someone.
              I bought about 3 thermistors and they are somewhere......
              If anyone has a thermister and the loom please PM.
              David
