Morning All,
Anyone have the same problem and how do you adjust or repair Tacho to zero, I replace instrument lights in Cluster. When I connected every thing it stays at 1500 RPM when ignition switched off. RS2 REV COUNTER.jpg
As above. If you removed the pin when you did the work it wasn't replaced in the correct position.
After correcting, flick the needle clockwise a couple of times and it should return to zero each time.
