OK peeps I've tried searching on here found a few helpful threads but still no luck, My hazard lights work fine but indicators don't even though the relay that clicks with the hazards clicks when I put the indicators on please
Indicators not working
After hours of searching through the 30 year old worn out wiring and checking everything you can imagine we found the fault Dodgy hazard light switch Never though that would be it, hazard lights worked fine but whatever the issue inside the switch stopped the indicators from working.
One for the check list if anyone has a problem in the future
- 1 like
