Indicators not working
  • Rikki Kitto
    • Feb 2010
    • 6276
    OK peeps I've tried searching on here found a few helpful threads but still no luck, My hazard lights work fine but indicators don't even though the relay that clicks with the hazards clicks when I put the indicators on please
  • K Simmonds
    • Dec 2007
    • 7632
    The first I'd place check is the stalk and it's conection block.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
      • Dec 2017
      • 6006
      I get this occasionally. Give the top of the cluster a tap.
      • Rikki Kitto
        • Feb 2010
        • 6276
        After hours of searching through the 30 year old worn out wiring and checking everything you can imagine we found the fault Dodgy hazard light switch Never though that would be it, hazard lights worked fine but whatever the issue inside the switch stopped the indicators from working.
        One for the check list if anyone has a problem in the future
        • audiwhore
          • Aug 2010
          • 9
          Came here to say hazard light switch, going through a 3b thats been off the road since 2008. Dealt with the same issue last week
          • Rikki Kitto
            • Feb 2010
            • 6276
            Do they have some sort of circuitry to combine the two systems inside the switch then?
            • Rikki Kitto
              • Feb 2010
              • 6276
              Other good news, my right side indicator now works after not working for many years
