Reading messurements from the ecu pins
  • terrybullwon
    • Mar 2006
    • 8782
    Using a multi meter how do i read the resistance or is it continuity i am looking for? on the ecu pins?
    I have the right setting on the multi meter, just dont know how i need to go about to
    Most keen on knowing 49
    Pin outs
    Chef
    • 12431
    James,
    If its resistance you are checking put multimeter leads into com & V+ then put one lead to the ECU pin 49 and the other to where the cable terminates on whichever sensor/actuator and take the measurement
    • terrybullwon
      • Mar 2006
      • 8782
      Originally posted by Greg_S
      James,
      Thanks Greg,
      So i have to go to the sensor in the engine bay basicly
      Chef
        • 12431
        yup, the plug that goes to the sensor
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          A quick way to check for continuity, set your multimeter so it beeps when you touch the probes at the end of the two leads together.
          Then put one of these probes into each of the pins you want to check. In this case ECU plug pin 49 and the corresponding pin on the connector that plugs onto G4.
          If you have a connection your multimeter will beep. If there is a break in the cable or no connection, it won't. If that makes sense.
          HTH
          SS
          • terrybullwon
            • Mar 2006
            • 8782
            I think i have a connection to the ecu
            Which means the ecu is the suspect
            Chef
