Hi all, I've searched the forums to find my answer but no luck, so wheres the fuel pump relay on my 3b..??
I've joined the ranks of the car won't start crew, I replaced my boost hoses over the weekend great job went reasonably well finished replacing hoses started up to move car off the ramps to refix the bumper, reved her up abit then she backfired and engine cutout and now won't start! engine turns over , there appears to be no spark at the plugs and looks like no fuel as plug was bone dry when I took one out. I've checked fuses in the underbonnet fusebox had a look under the drivers dash area.. so back to my original question where is the fuel pump relay located?
If anyone has any fix it ideas ie check this do that ect please feel free ha ha..looks like I may have to make a phone call to my mechanic....ok bfn a grounded Condor
Mines still giving that code and not starting..... Might be worth checking your earth connections and checking for a spark.
