Hall sender issues me thinks
  • Knight Rider S4
    • 3541
    This morning i went to the car and it would not start fuel everything was there could smell it ..so thought to myself Hall sender so got some water pour over the back of the cam sprocket and she fired up but was very lumpy to begin with like it was running on 4 cylinders for a minute.........So i am wondering have i moved something or upset it when changing coils over?..(have just done coil conversion)...or just bad luck?..........Have done searchs on changing over and read a post by Jas about his brother using cable ties on the belt on the cam sprocket loosing tensioner and slipping off belt/sprocket then change over ..is this right?
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
  • PeteRR
    • 1326
    There must be something in the air, my S4 decided not to start this morning either.
    Hastily tried the cold water trick but nothing doing. I'll have a proper look tonight, as much as I can. I wish I had Vagcom!
    The thing is, a couple of days ago it did missfire at idle a couple of times for a few seconds, I had optimistically put it down as being low on fuel. It was fine yesterday though, but did go flat/missfire at high-ish boost.
    Any pointers for us poor AAN-ers?
      I think you missed the only sign that your fuel pump was dieing, and now it is dead. Try following this procedure I wrote for the AudiWorld AAN FAQ to confirm your problem:
      http://forums.audiworld.com/s4s6/msgs/149788.phtml
      If nothing electrical shows up as the problem, then its probably your fuel pump. A testing procedure that I wrote is at:
      http://forums.audiworld.com/s4s6/msgs/161382.phtml
      IF the fuel pump test shows that its dead, a replacement procedure is at:
      http://forums.audiworld.com/s4s6/msgs/149784.phtml
      Good luck.
      Dave F.
      • PeteRR
        • 1326
        ******!, I think your right there Dave. I shall have a look tonight to try to confirm.
        Typically, I went and put 3/4 of a tankfull of Shells finest in only yesterday too.
        Thanks for the advice and v.helpfull links though!
        • PeteRR
          • 1326
          Hmmm, she started straight away when I got home tonight.
          All I did was check the fuel pump fuse and pour some more cold water down the back of the cam pulley again. Though a little more this time.
          Seems to point to a possible Hall Sender prob then. Going to book her in for a check over.
          • Knight Rider S4
            • 3541
            Good luck.
            Dave F.
            Cheers Dave ...you are a legend!!
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
              <Blushes> Well, maybe (in my mind). (Thanks for the kind words)
              Don't forget that there is the inexpensive BB Automacao Hall Effect sender (CYHME301) at:
              Document translation services. 100% Guaranteed. We translate all foreign languages. 24/7 Certified translation services. Get a Free Quote Now!
              Dave F.
              • Knight Rider S4
                • 3541
                Thanks again Dave ..great link they are cheap as !!........vag are wanting £80 for one !!
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
