after looking through the pages here i noticed that choosing a better maf is not an easy task.I need to build an engine that according to Mihnea is the limit for the RS2 MAF and i want to be sure that everything stays intact and doesnt cause problems all the time.
Which is the main problem of the MAF when using a big turbo?Is it the reverse direction of the air coming in the maf?Or is it the high boost pressure of the turbo that causes the rupture of the string?
If the first part is the issue,then relocating the MAF to the pressure side and remapping should give the answer to a safe 450hp without looking for a new MAF every month.
However if high boost pressure is the problem,then getting the maf to the pressure side again should cause problems.
So what is the answer here and how a SQ is better-stronger than the RS2 maf??
thanks
VAsilis
thanks
VAsilis
