Does anyone knows, what to do with the dashboard if i install AAN into the ACQ`85 with the simple KV engine...
at first, i'll use the S4/c4 dashboard, but it's not for b2....
so, the stick dashboard is too old ...
maybe i must search the sportquattro or urq dashboard???
no problems. the taho signal from the ecu direct to dashboard taho signal. The rest of warning signals are the same.
I have done the conversion in my coupe without problems.
The oil pressure warning relay has to have the taho signal from the coil directly because the ecu signal is to low for that relay.
I have 3b engine. dont know about AAN.
AAN loom has different connectors(fuse board side) to ABY and 3b as i found out last week from Sal,im sure that it will work ok but wont be such an easy job.I will have a look at my loom in more detail over the weekend and see if its going to be worth the hassle as i am doing the same conversion soon.
