Need to find switched feed for heated seats
    replied
    No worries
  • topsparky
    replied
    Topsparky, didn't see any bolts on the relay carrier. These 3Bs are all different though..[/QUOTE]
    sorry newsh never worked on a 3b
    just assumed (asumption is the mother of all F U's)
    it was the same as my urs4
    generic relay carrier and all
    my bad
    replied
    @ Acidburn, Mine is a 92 and doesn't have the dim-dip AFAIK sorry.
    The guy who said he'd take pics is C4mby on here I think.
    Originally posted by Acidburn
    @newsh - on a quick side note if you happen to see that wire that you mentioned I needed to find to do my sidelight problem with could you take a quick snap of it as i'm yet to find it
    replied
    Thanks guys, I did find a wire from the ignition switch, its the one I used to power the plasma gauges, I had a bit of a breakthrough when I realised that the red wire does need to go to an "on all the time" power feed, the relays are switched by the smaller wire. (I thought the smaller wire was just for the lights in the switches So I spliced the red wire into one of the live feeds on the big tags.
    Biggest struggle goes to getting the fuse into a vacant hole in the fuse box, felt like hours laying in the footwell soaking up the damp from the carpet trying to reach the fusebox and feel the fuse into place, got it in the end though
    Jas, that tip from Glynn is a good one, I'll remember that in future.
  • Acidburn
    replied
  • Jas11n
    replied
    Pictures and explanation by GlylnRS2 >>>> Here.
    Jas..
  • topsparky
    replied
    if you look where the relays are under the steering wheel
    there should be some bolts at the bottom of the
    relay housing some are switch feed some are permanent
    feed
    hope that helps mate
    started a topic Need to find switched feed for heated seats
    Nearly there with my loom install but need to find a power feed. All the big spades on the bottom of the fuse box are in use (2 rows of 4) but anyway they are on all the time meaning if I leave a seat heater on I'm looking at a flat battery.
    My fuse box cover says fuse 3 is horn and heated seats but I'm not sure how to access this fuse, after all these years with quattos I still dont understand how the fuse box works There's so much stuff crammed in under the fuse box I can't see it very well.
    I also need to pick up a feed for the power to the switches for the lights, if there's an easy way to do this. My car does not have the yellow connector block on the aux relay plate, mentioned in the how-to. I can always get one from the glove box light if I have to though..
    Car is a 3B.
