power windows relay RS2
  • A80Avant
    • 10873
    • Country: Greece
    anyone has any relay willing to sell me?pm me..
    mine seems to be failing...
  • s20ale
    • Aug 2004
    • 476
    Pop the old relay apart and look for any arking.
    My relay had a burnt main earth contact, re-solderd and work's a treat, that was over a year ago.
    All depends if your that way inclined, i still have that little boy instinct (@ 30 something) & cant help but pull stuff apart especially if it has to be replaced.
    • amanda
      Account Disabled
      • Nov 2006
      • 524
      If you have the part number I may have something that may fit
      • A80Avant
        • 10873
        • Country: Greece
        unfortunatelly i dont have the part number.i will look for it at ETKA
        as for the soldering,never tried it,im good with hands,but jave no tools!!! more negatives together
        i will post a part number if etka obliges me!
        • A80Avant
          • 10873
          • Country: Greece
          only relay number i could find is: 443 959 257 B which is for power windows and sliding roof.Although i dont have the roof,there is no other relay for the windows.
          • s20ale
            • Aug 2004
            • 476
            Just to confuse things http://www.vagcat.com/ say's part No for relay is 8AO9O7525.
            I know Audi have a habbit of changing p/No's just to make thing's easy.
            • A80Avant
              • 10873
              • Country: Greece
              that part number gives it as the fuel pump relay on my etka
                vagcat is ropey...
                PapVas - you have the right number there I am sure. Its a double-width relay module and works with electric sunroof where fitted - there is no separate controller for that.
                These are silly expensive from new - but are common fitment in all 80 variants with electric windows - easy enough to source from breakers at low cost.
                Paul
                • Graham
                  • 1622
                  I aquired one a while ago from a 80 and it is different fro the one i have under the dash, will dig it out and find a part number.
