Alternator woes.
  • Nuvo
    • Nov 2003
    • 3826
    Alternator woes.
    I'm experiencing charging problems at the moment. I replaced the V-belt, the regulator is fine as I replaced it about 1 year ago. I suspect the slip rings to be at fault as they have deep grooves in them so I want to strip the alternator down to replace them.
    That were my problem lies, the 4 long philips headed bolts face towards the front of the car so they have had years of exposure to the elements and a little corroded. I soaked them with plus gas and tried to crack them free. The first screw head started to crumble a little so this doesn't fill me with confidence.
    I used a philips drive socket and managed to sheer the tip of it off (Halfords Pro tools).
    Any BTDTs? I want to be able to reuse the bolts again if possible (I don't think these can be ordered separately) and I'm reluctant to use a stud extractor as these will destroy the bolts and have a tendancy to snap when using the smaller ones.
    EDIT: The cheese head bolts are available separately so that is a big help (phew).
    I hope someone can help as I need the car back on the road as soon as possible.
    Thanks.
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Give then a tap with an impact driver.
    SS
    • Nuvo
      • Nov 2003
      • 3826
      I forgot I had one of those. I'll give it a go. Thanks Stu.
      • s2driveruk
        • 12696
        soak the ends in penetrating oil too as its only threaded at the base....apparently. A local alternator specialist should be able to supply replacements though
        1992 3b S2 Coupe
        • Nuvo
          • Nov 2003
          • 3826
          Another top tip. Thanks David.
