Fuel Guage Sender replacement
  • Bowlerwell
    • 1052
    I have my new fuel guage sender ready to fit.
    In preperation I looked up my manual... which only has the instructions for the 3b, but how different can it be...?
    I removed the metal cover (which looks like it has been butchered by previous owner), and proceeded to remove the electrical connection, and both the 2 fuel pipes.
    Here's the question... Without 'Audi tool xxxxx' how do I get the thing off? I assume it just unscrews, but it does seem quite impossible...
    Any BTDT, or other hints and tips?
    Thanks,
    JohnB
    Last edited by Bowlerwell; 22 February 2008, 18:47. Reason: spelling errors... oops
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
  • Knight Rider S4
    • 3541
    Just stripped mine easy enough job
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Bowlerwell
      • 1052
      Fantastic. What a hero.
      Thanks for the info.
      So it's the black sleeve only that unscrews yeah? And i just need lots of brute force?
      Thanks,
      JB
      John Bowlerwell
      Electronic Engineer
      Present:
      Previous:
      • Knight Rider S4
        • 3541
        Yes unscrews ..I tapped it round with wooden shaft of a hammer..remember to loosen the pipe first before taking off..when putting back on screw as if you are taking off until you feel it drop and catch then wind on very easy to cross thread as it is plastic
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • Bowlerwell
          • 1052
          Yep, i'll remove the pipes before unscrewing.
          Will post results tomorrow when I get the job done.
          John Bowlerwell
          Electronic Engineer
          Present:
          Previous:
          • Bowlerwell
            • 1052
            Job done. Now in full working order.
            Thanks,
            JohnB
            John Bowlerwell
            Electronic Engineer
            Present:
            Previous:
            • Bowlerwell
              • 1052
              To what torque should I tighten the fuel send bolt?
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
              • Bowlerwell
                • 1052
                Bump...
                Question as above... anyone?
                John Bowlerwell
                Electronic Engineer
                Present:
                Previous:
