Bulb for ambient temperature display
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    Got a 3mm 12v diode from local supplier, but it was way too weak. Seems that I need the superbright version that Maplin sells (CJ70M). However, Maplin wants £40 to ship this 1 gram £0.39 bulb to Norway, which is slightly ridiculous...
    Does anyone know of another place to get them, or have some spares kicking around?
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
  • Bowlerwell
    • 1052
    Surely there must be an electronics supplier in Norway?
    None on Ebay?
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      None on Ebay?
      No 12v high output ones on Ebay (need to have internal resistor due to limited space), and the Norwegian electronics supplier only stock the low output type.
      1994 80E Avant
      • shark_90
        • 1475
        I need one of these myself, so if you let me know what it is we need I'll get some and post one over to you
        1994 Audi S2 Avant - in pieces
        2006 Skoda Octavia vRS 2.0TFSi - goes fast
        1985 Audi 90 quattro - is wet
        Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
        • k.alle
          • Feb 2008
          • 801
          But do you really need a LED?
          I did this one yesterday and my weapon of choice was a 12V 60mA sub miniature bulb.
          Worked a treat, and no more hassle for the next 10years?
          Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
          http://www.garaget.org/?car=52877
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            Stock bulb is a sub miniature type, but they have a reputation of burning out pretty quickly. Where did you get it? Elfa? Part number?
            1994 80E Avant
            • Azman
              • 3205
              Ahem, scuse me for being thick, my ambient temp display is just an LCD when the lights are on I can't see the temp. Is this wrong should it be back lit??
              Dark Grey Avant
              RS2 FARB
              Alloy Subframe Bushes
                • 12431
                It should be back lit aswell, the bulb replacement is quite easy
                • Bowlerwell
                  • 1052
                  I have always used the sub miniature bulb in the past. It's been fine.
                  John Bowlerwell
                  Electronic Engineer
                  Present:
                  Previous:
                  • k.alle
                    • Feb 2008
                    • 801
                    I bought it from Kjell&Co:
                    Ladda upp inför Black Week och Black Friday på Kjell.com Att bli medlem hos Kjell & Company är ett smart sätt att förbereda sig inför både Black Week och Black Friday.
                    Couldn't find one @ ELFA.
                    I have some left overs, if you like I can throw them in an envelope and post them to you?
                    Perhaps that's not an option if you want them ASAP.
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      That would be grand
                      PM sent
                      1994 80E Avant
                      • EspenW
                        • Apr 2007
                        • 1534
                        • Country: Norway
                        Thanks for the offer , but one is on the way across the border from Sweden.
                        This is the LED that is needed:http://www.maplin.co.uk/module.aspx?...=35738&doy=7m5
                        1994 80E Avant
                        • montyrs2
                          • May 2008
                          • 522
                          An old thread but has anyone done this recently? The maplin link goes to the home page and I am no electronics whizz so I need my hand holding.
                          Anyone know what the current maplin part number is or the spec of the bulb? Pretty sure I can get someone at work to do the soldering for me to save me from destroying it!
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            12v 60mamp grain of wheat/rice bulb make sure you get the correct m amp mine is 70 and is too dim gotta change it when I can be bothered
