Hi need help on the relay values and what they are for on relay and fuse box under the hood, for the RS2 , (ADU).
There are 11 relays there and 32 fuses. The relay number 9 in mine is missing, and i have to know what it is for. Also i would apreciate a pic with what each relay does and it's value and part number and the same info fo the fuses too. (From an english manual maybe!)In my car it's in german ( for the fuses only but no info on the relays).
I checked the s2 central but no info on the relay values.
Just checking if this could be a solution tomy problem !
Thanks nick
Thanks nick
