Blower on Lights go off -- Help pld
  • s2bug
    • Nov 2007
    • 484
    What an ****
    Have taken stereo out as selling S2, 3b and now when I turn the blower on the Lights go off ??
    The windows start goping down cm by cm
    and there is a clicking coming from Top RHS of the drivers dash ?
    One of the relays maybe?
    Help please as dark outside
    Many thanks
    J
    S2 Avant ABY
  • Nj
    • Jan 2007
    • 3420
    • Home: Scotland Current: Finland
    It's probably worth taking off the panel under the steering column to get at the relays and see what one is doing the clicking. That might be the easiest way to suss it out.
    When you took the stereo out did you unplug a block connector or was there a bunch of loose wires to untangle? the general witchcraft you describe would suggest a mad earthing issue to me so all I can think of is the stereo has been removed and an earth is shorting against a live, or a live is shorting against any earthing point or something along those lines. If there is any spaghetti i'd make sure every loose wire is individually insulated.
    Might be worth checking to see if someone has piggy backed a live or earth onto the feeds for the blower
    good luck
    Nj
    1990 CQ20v
    • S2Ian
      • Oct 2006
      • 310
      check all of your wires on the main stereo loom, sounds like your live wire from the fuse box maybe damaged/stripped wire and is connecting to another wire, i had similar fault a few months bakc and found it to be a damaged wire on the stereo loom & it was connecting with a wire and triggering a relay on teh main circuit.. hope this helps..
      S2 Coupe, ruby red, 95 - Slight mods
      A4 Tdi avant, many greens, 97 - Workhorse
      • s2bug
        • Nov 2007
        • 484
        Thanks guys
        Does sound like a naughty earthing going on...
        Will check all through
        S2 Avant ABY
