I've searched the forums, but haven't found anything on the subject so here goes.
Does anyone know if the voltage guage can be adjusted/calibrated?
When I first bought the car, GT500 mentioned that the reading looked a little low. The car had been fitted with a new alternator and he suggested checking the regulator on the rear. It was a 14V reg, so I replaced this with a new 15V one.
The indicated voltage has gone up but still reads low by about 1-1.5 volts. (I haven't actually measured the voltage on the guage, but don't want to go to the trouble of removing the console unless I know that there's something I can do to adjust the indicated voltage)
Battery is good and has been charged separately.
It doesn't bother me enough to replace the guage but if I can "fix" it, I'd rather have it working correctly.
Andy
Andy
