Volvo T5 engin loom
  • badass/s2
    • Dec 2008
    • 15
    . miss typ
    • badass/s2
      • Dec 2008
      • 15
      it boost up ok in the cold but when its warm runs lumpy cuts out and smells of fule.
      • terrybullwon
        • Mar 2006
        • 8782
        Cuts out? Like after a hard run and you stop at a junction?
        Chef
        • Acidburn
          • 13459
          has anyone tried a boost leak test on it? That would be the first thing i'd try after pulling the codes and seeing what happens.
          • caterpillar
            • 2480
            #20
            you have to kontr the ingnitin switch( behind the keylock), and the earth( ground) ... thats the most typicl fail in audis....
            if you have low volt att the battery poles; you have to change the regulator in the generator to a bigger one ( marked to 15v).... gives 14,7-14,8 att the battery.do not cost mutch..
            • badass/s2
              • Dec 2008
              • 15
              iv just had a full set of custom sam cos on it and new inter cooler holds boost on a normel drive it just cuts out coming to any stop.
              • caterpillar
                • 2480
                #22
                do not think the volvo t5 loom will fit..... no way
                • badass/s2
                  • Dec 2008
                  • 15
                  i have herd about the problem iv gone though the whole wiring loom and checked it all out and it seems to be ok
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Mine used to cut out, i replace the ignition switch as the 17 years with heavy keys on it had killed it.
                    Chef
                    • badass/s2
                      • Dec 2008
                      • 15
                      ill have a look mine is from 1991 to so its 17 years old
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Shame... I was on the IOW but i have moved to Bath now. I would have had a look for you.
                        Chef
                        • badass/s2
                          • Dec 2008
                          • 15
                          well thats just bad luck init
                          • pastures16
                            • 2058
                            hasnt sal got one knocking about give him a pm
                            94 s2 avant
                            aoc member 1116
                            • Acidburn
                              • 13459
                              afaik aan or aby but i did not see/hear of any 3b's when i was up there the other day.
