Another dead battery
  • shark_90
    • 1475
    Yes it's bound to be the alarm/central locking that's doing it on mine. Not measured the current draw but to be honest it wouldn't make a blind bit of difference if I did as I won't be able to find it anyway, not in this weather!!
    I charged my booster pack last night to enable me to at least move the car, then I'll run the car on the battery and see if the alternator can give it a kick start, enough to allow it to charge maybe. Then I'll disconnect the battery.... or take Mark up on his offer!!
    I've also seen a Hella master switch jobbie in the back of Audi Driver, might buy one of those but for £15 I think I can just disconnect the battery!!
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
      Fit a motorsport style battery cutoff, it'll look cool too
      • Bram
        • Aug 2006
        • 2582
        EXIDE Maxxima 900 DC Auto Battery
        Anyone have experience with this gel-type battery (http://www.leab.de/english/exidebatt...y/index.html)? I can buy one for 159 Euro (+30 Euro shipping) on Ebay.de and it looks like a good price.
        The specs are as follows (sorry they are in German):
        Technische Daten EXIDE MAXXIMA
        Typ
        MAX 900 DC
        Abmessungen (LxBxH/mm)
        260 x 173 x 206
        Verschlossene Batterie
        ja
        Gewicht/kg
        17
        Ausführung
        4-Pol mit integr. Tragegriff
        Kaltstart A (EN)
        900
        Kapazität (20h)/Ah
        50
        Ladestrom/A bei 0o C,14,4 V
        55
        Ladestrom/A bei 25o C,14,4 V
        >100
        Startzyklen nach SAE J240 bei 40o C (soll >4300)
        8600
        Startzyklen nach SAE J240 bei 75o C (soll >2150)
        3870
        Zyklentest nach DIN-EN 60 095-1
        >160
        Rüttelfestigkeit nach DIN-EN 60 095-1
        20h 6g
        Now I probably would need a special battery charger for this gell battery, with the following requirements:
        Externes Laden der MAXXIMA-Batterien
        Zu verwenden sind ausschließlich Geräte mit den Kennlinien IU oder IU1U2 und folgenden Eckdaten:
        I-Phase mit Stromstärken zwischen 10 und 30 A/100 Ah.
        U-Phase bzw. U1-Phase (Hauptladephase) mit konstanter Spannung zwischen 14,1 und 14,4 V.
        U2-Phase (Ladeerhaltung) mit konstanter Spannung von 13,8 V.
        Ladezeiten: Phase IU bzw. IU1 mind. 12 Std., Umschaltpunkt für U2-Phase nach 12-16 Std.
        Can you recommend one, because I have no idea what these terms mean.
        • sheppardnias
          • Jan 2008
          • 170
          This is almost certainly irrelavent but never mind...
          Do the problem cars sit for longer and still run if the battery has just come off a mains charger?
          I've battled with the battery going flat in my URS6 for a year. Done all the drain tests etc and found a few gremlins but nothing major.
          Used to be that with nothing on (lights etc) that the voltmeter inside would show 14V but dropped under load. At the battery the couple of times I checked it seemd up at 14V though. Alternator was new, battery new and huge (looked more at home in a tractor). I cleaned earth points all over assumed there was a bad one somewhere but that I was too dumb to find it.
          After 3 days the car would never start and even when just run turned slower than I expected but not crazy slow.
          The other month I went to it and it was dead leaving me stranded at work. Touched the battery terminals and it came back to life. I fiddled with it cleaning terminals etc but no change. Turned out the original Audi battery clamps on the positive feed and supply from the battery had corrosion within the crimped area. Discovered it by spraying electrical contact cleaner inside the crimp and watching the charge voltage rise.
          Cut the clamps off and replaced them, the car is a different beast. Can be left for 2- 3 weeks with no problem and spins much much faster on the starter. Under any amount of load the voltmeter barely flickers. I guess the corrosion was increasing resistance to such a level that the battery barely got any charge.
          Might be worth just checking....
          • johne
            • Apr 2007
            • 1406
            [QUOTE=bram;383882]Anyone have experience with this gel-type battery (http://www.leab.de/english/exidebatt...y/index.html)? I can buy one for 159 Euro (+30 Euro shipping) on Ebay.de and it looks like a good price.
            Typ
            MAX 900 DC
            260 x 173 x 206
            ja
            Gewicht/kg
            17
            Ausführung
            Kaltstart A (EN)
            900
            Kapazität (20h)/Ah
            50
            55
            >100
            8600
            3870
            >160
            20h 6g
            I can't see what advantage you'll get from a gell battery unless you roll the car
            Given it costs twice the price of a good Bosch Silver standard battery, I'd save your money for something else on the car!
            John
            • johne
              • Apr 2007
              • 1406
              If you've got starting problems it's always worth checking the voltage drop between the battery terminal and the starter motor. I accept this is easier said than done and you'll need a good voltmeter with long leads + an assistant. One lead needs to go to the centre on the lead battery terminal +ve, ie direct onto the battery. The other lead needs to go the the big terminal on the end of the starter motor. Crank the engine. If you see more than 1 volt on the voltmeter start looking for corroded connections. Do the same for the -ve side. Go from the centre of the lead post -ve on the battery to a good earth connection on the engine, eg the earth stud on the inlet manifold. Again crank the engine and see how much voltage drop you get. The less the better.
              John
              • sheppardnias
                • Jan 2008
                • 170
                If the engine turned, it started. But within a week the battery was so flat that the interior light barely lit. I had no reason to think that the battery was just not getting charge. In hindsight I could kick myself for not thinking of original leads being faulty. I just thought that it had to be something else. The time I wasted on this made me feel so bloomin stupid.....
                Still you live and learn!
                • Bram
                  • Aug 2006
                  • 2582
                  John
                  Hi John,
                  Thanks for the tip, however i am 99% sure my batery is dead, since the Avant has been standing still for 4 months and before that time the 30 Euro battery already gave me some starting issues on short rides.
                  • Henkjan
                    • 1705
                    had a dead battery problem for some time now.. decided today to at least find the cause.. so I went to the car armed with my amp meter. and with everything off it drew 0.7A dropping to 0.4A after the CD changer was ready with reading CDs.. so started to pull out the fuses, and #4 out showed a drop to 0.05A.. long story short: it was the light in the bootcompartment that was lit all the time took the bulb out, just hope that the battery has not died after being drained completely empty
                    on the subject of gell accus: they are much better suited for cars that are not used frequently, normal lead/acid can die if drained, gell accus apparently are less prone to this
                    • Bram
                      • Aug 2006
                      • 2582
                      I just bought a 85 Euro battery from Brezan with 2 year warranty and 75A. It's originally some Japanese brand who make also batteries for other brands I believe. I learned from my friend Nero that a battery is only used for starting the Avant. Better spend the money on engine components is what he says. I have to agree with him
                      • Henkjan
                        • 1705
                        as long as it's good enough to start... you'll look prety silly with those expensive parts doing nothing
