HID lights problem
  • JamesHarrold
    • Feb 2008
    • 245
    HID lights problem
    Hi Guys...
    Just started to notice that every time I turn the lights on they start to illuminate very slowly before flicking off totally just before they get to full power. It used to be just the off side but now its both.
    Also noticed that near side sidelight is starting to flicker slightly.
    Sorry, I know ****** all about these HID light and they were on the car when I bought it, so cant even blame myself.
    Any help would be much appreciated.
    James
  • Tonks4x4
    • Nov 2005
    • 3062
    First thing is check the contacts where they plug into the original bulb plug.
    AshEngland had identical fault the other night, popped the bonnet gave them a quick unplug , bit of emery paper and plugged back in. Been ok since.
    Audi Nut!!!
    • Fat Audi 80
      • 10547
      Also check your earth connection is still stong and to bare metal, this will also cause them to fail.
      (Do you have them dipped beam set up correctly too? In some S2's, generally early ones, the dipped beam goes off when you flick to main beam. You must make sure the dipped beam stays on ALL the time or it will kill your HID's..)
      Just a thought, in case it could be that.
      Cheers,
      Steve.
      The Perfectionist
      • JamesHarrold
        • Feb 2008
        • 245
        Thanks guys, will check all the above.
        Interesting point about the dipped beam being on all the time....will check it in the morning. What does it point to if I find the dipped beam dont stay on when on high beam?
        James
        • s2driveruk
          • 12696
          just means that a small wiring mod on the stalk hasn't been done from memory....
          1992 3b S2 Coupe
          • JamesHarrold
            • Feb 2008
            • 245
            Ok...will check it and let you guys know. Does anyone have a description or diagram of the mod on the lights stalk if I find that its not been done?
            James
            • s2driveruk
              • 12696
              this might help.....
              1992 3b S2 Coupe
              • JamesHarrold
                • Feb 2008
                • 245
                Many thanks for the link.... Day off tomorrow, so will investigate then and let you know.
                Many thanks
                James
