Rev counter
  • Colesy
    • Feb 2009
    • 2982
    Rev counter
    Hi all,
    I'm looking at buying an S2 which has a broken rev counter, the seller has plugged in a set of clocks from an audi 80 and the rev counter works. So the assumption is that it is just the rev counter that is broken.
    So my question is, can the rev counter be taken out of one set of clocks and put into the another set? This would save on replacing the whole set etc. Or would it be safer to just get a new set of clocks? If so where could I get one from?
    Thanks in advance,
    Will
  • Acidburn
    • 13459
    You can buy the rev counter seperately or get one from a spare cluster.
    Clusters do come up cheap from time to time.
    I've yet to hear of one going wrong tho, only thing I found with my s2 was it was useless at keeping up
      haha... AFAIK you can put the white face on a common black 20v rev counter, its the same dial underneath
      • Acidburn
        • 13459
        Yeah you can but its getting the needle off the dial without damaging the innards, btdt
