Replacement electric pins for connectors
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    Hi need to change some wire outer casing on my injection cables as they are very brittle
    Is it possible to buy the pins for the fuel injection connectors & also the grimp tool
    Thanks Wayne
    RS 2 580HP
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    You can buy the pins attached to a repair loom. The cable only comes in yellow now. I found the insert inside the 2 pin electrical connector becomes very brittle, so it may be worth getting a set of those too, P/Ns 000 979 133 for a piece of 1mm cable with a terminal each end, and 443 906 232 for the connector housing.
    I did have a thread on here with more details, but is seems to have disappeared.
    SS
    • Nuvo
      • Nov 2003
      • 3826
      This one?
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Originally posted by Nuvo
        This one?
        Nope. Go back about 4 more years.
        I had to replace a few of my injector plugs as they were falling apart causing a misfire.
        SS
        • Nuvo
          • Nov 2003
          • 3826
          That'll teach me to read the post properly instead of skim reading.
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Looks like the old thread has been deleted.
            No worries Rob, at least that link may be of use if Jade just wants to remove the old pins and replace with new.
            SS
            • jade
              • Jan 2005
              • 1811
              I did have a thread on here with more details, but is seems to have disappeared. [/QUOTE]
              Thanks for the info, so its not possible to buy connectors ready to be crimped. so it looks like i will need to splice the wire in to loom then.
              RS 2 580HP
              • Graham
                • 1622
                Is this what your looking for
                • jade
                  • Jan 2005
                  • 1811
                  Thats it Thanks
                  RS 2 580HP
