why do my coil packs keep melting????
  • WabTheKing
    • May 2004
    • 2567
    abz v8 running a vems ecu
    fresh set of coils (later type) but still keeps cooking them?????
    anyone have any idea's??
  • Acidburn
    • 13459
    How long does it take for them to fry? after a few minutes or once the engine is warmed up?
    i'd say heat or wired up somewhere wrong?
    • WabTheKing
      • May 2004
      • 2567
      only running for a few mins cause the rad isnt connected yet, then once its turned off, or stalled - couple of minutes the odd one (not the same one each time) starts smoking
      • Knight Rider S4
        • 3541
        Earthing would be first thing for checking ?
        93 S2 Avant Parting
        91 URQ RR
        02 A4 tdi Avant
        • AndyP
          • 6049
          Have you had a multimeter on the supply to the coil to see what it's actually getting?
          • WabTheKing
            • May 2004
            • 2567
            not yet, ecu had suppose to have been tested on a rig after the first time this happend, need to find out what these coils should run at and get a multi meter on the loom wires and see what they are putting out
            • a4kquattro
              • Feb 2005
              • 411
              too much dwell? what is your settings? what firmware?
              Marc Swanson
              Proprietor, EFI Express
              95.5 //S6 Avant
              90' Coupe Quattro V8 4.2L twin turbo
              93' //S4
              83' UrQ
              97' F250 7.3 diesel
              • WabTheKing
                • May 2004
                • 2567
                can send you the file if you want to have a look at it?
                • johne
                  • Apr 2007
                  • 1406
                  Sounds like uv got a wiring mix up so that when the engine is off or when it's stalled one or more of the POS (coil drivers) is being held on and sinking full current through a coil primary continuously which will cause them to overheat and burn out.
                  John
                  • WabTheKing
                    • May 2004
                    • 2567
                    that sounds feasable, as i can never recall it burning one out when its running
                      Eiether a wiring / earthing problem or too much dwell as suggested... Need to check coil specs are compatible with dwell times provided by ECU.
                      • BRY
                        • 3755
                        Sort it and then you can tell me.
                        Found an MOT yet?
                        • Larry Carr
                          • Feb 2005
                          • 63
                          As per the melting coilpack issue, hopefully, mine's been sorted out, I'll let you know Will.
                          L.Carr
                          • GazzaG60
                            • 4133
                            id go with the dwell too. need to be set to offer the correct spark power but not generate too much heat.
                            my settings are
                            chargetime @ 14v 3.01
                            chargetime @ 6 v 1.51
                            cheers
                            • Larry Carr
                              • Feb 2005
                              • 63
                              Gazza, the dwell times are only applicable to a running engine - these meltdowns only occur during a stall situation, or if the ignition is left on, for instance, when running Megatune.
                              So, reducing the dwell time - even to the point the engine would start to missfire at high rpm, won't cure the issue.
                              My VEMS is back tomorrow, and there's a modification that needs to be applied to the harness, which I'll be doing later on in the day, will keep you guys posted.
                              L.Carr
