Hit boost and all went dead - help
  • s2bug
    • Nov 2007
    • 484
    As above, out this morning bedding in brakes, hit boost - braking , hit boost and engine cut out.
    Tried to restart and seemed like no petrol getting in, no smell of excess fuel either so would this be the fuel pump fuse?
    Really not sure what else .... apart from a blocakge in the fuel line.
    Opened boot to listen to the pump, not a wisper .... hmmmm
    and the fix is ?
    Help, please
    S2 Avant ABY
    Bet you've blown a hose off the inlet. Better check it all and make sure. I've done this by blowing off a hose on a couple of occasions.
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      I second Andy's sugestion. Had the same exact symptoms the other day when an IC hose blew off on a S4.
      1994 80E Avant
      1986 2L Golf 2 on Alcohol
      • s2bug
        • Nov 2007
        • 484
        Inlet hose attached from IC?
        Makes sense ..
        I have had this before and gives loads of steam out the back ... will check though ..
        S2 Avant ABY
        • Al Wyn
          • Nov 2006
          • 3746
          Sorted J?
          S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
