ok here's a wierd gremlin
    Originally posted by s2driveruk
    i am sans deadening felt and you can hear everything Some of it i'm sure is normal, this particular issue i have is not i'm pretty sure
    I'm removing the tar stuff
    • rj scotty
      • May 2006
      • 2195
      I removed to tar on my mk1 golf it's a biiiitch of a job.
      Loads of celly thinners required.
      BUT I DON'T WANT A NEW CAR!
      1995 S2 Avant, Volcano Black
        had something similar in my mates dad's van - brake light switch was shorting and somehow making the speaker crackle. have you had your head right under there to see where its coming from? A rogue realy maybe?
        • s2driveruk
          • 12696
          Been trying to see something or feel something but so far at least it doesnt want to present itself....Yeah see the radio display sometimes lights up (as it should) and sometimes goes off. I must have a sh**ty connection or component somewhere but not found it yet. Seems to make the most noise on acceleration. I'll have to try and get an audio clip of it (not easy with no interior trim ) as its hard to describe the sound.
          I gave up this evening and clayed the roof, a & c pillars instead and had some polish therapy. Might sound cr*p but she's a looking glassy in the fading light
          1992 3b S2 Coupe
          • s2driveruk
            • 12696
            just to update this, I have been checking the wiring on the car a bit more recently and I have noticed a very fatigued main (red) cable off the alternator, heavy guage wire off the back of the fan was on its very very last legs with signs of heat damage and also the earth strap off the batter has seen better days.
            I'm presuming these might have some part to play in this but remains to be seen...
            1992 3b S2 Coupe
